Old 07-03-2003, 01:51 AM
plkelley's Avatar
plkelley plkelley is offline
Send a message via AIM to plkelley
Adjusting Valves (take 2)
Since my other thread was destroyed and out of 4 pages there was only one reply that had anything to do with the thread I have decided to start a new one.
On the intake side there are bars(no idea..could be rockers) that are right over top of the valves..on the exhaust side its easy to get to but how do you get to the intake side with the feeler gauge?
Honda...An Army Of One
Old 07-03-2003, 08:31 AM
91civicDXdude's Avatar
I just set the valves on a DOHC ZC the other day. the valvetrain looks identical to that of a B18A/B, so if you have any 3 of these engines its the same. You'll either have to get a special feeler gauge from honda, or take your old one and cut it in half so its half the width. then it shold slide right in.
On SOHC engines, its very easy. you shouldn't have any problems at all.
Old 07-03-2003, 08:33 AM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
there should some side of the valve where you can get the feeler guag into, thats the point, you shouldnt have to remove anything to make the adjustment.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 07-03-2003, 11:17 AM
plkelley's Avatar
Its a stock Si engine...the first time a tried I couldnt get to them but I'm going to try again soon. The knocking is annoying the shit out of me. Does the piston have be at top dead center or do you just watch the lobe on the camshaft for the lowest point?
Need help with 327 valve adjustment gr8hse67 Chevrolet Classics 6 04-04-2010 02:28 PM
How to adjust valves? lazerphreak Engineering/ Technical 1 05-08-2009 06:22 PM
Adjusting Valves? shawoo2 Engineering/ Technical 3 09-02-2002 11:21 PM
