Old 08-07-2017, 01:41 PM
BrianP BrianP is offline
Gas Leak
2006 Grand Caravan. Driving the other day and lost a quarter tank of gas in 20 miles. Got home and there is a high pressure spray of gas coming from what appears to be the middle bottom of the tank. After it was parked for a bit I felt under and there appears to be some fittings/hoses in that area. Any thoughts on what it could be and the extent of repairs? I'm thinking about junking it so don't want to put big money into it.
Old 08-07-2017, 04:27 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Gas Leak
Do you mean the top of the middle of the tank. That's where any hoses would be. I've read a good number of posts regarding leaks through hairline cracks in in the plastic pump housings on top of the tank. https://ww2-secure.justanswer.com/up...8_213607_1.gif
Junk it? Is it a rust bucket?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-07-2017, 06:55 PM
Re: Gas Leak
No - the tank is recessed in the middle of the tank on the bottom and there is a line there. The gas is spraying straight down on the ground. If it was leaking from the top I wouldn't see the high pressure spray.
And yes I've got one of the wonderful rust buckets from Dodge
Old 08-13-2017, 05:46 PM
Re: Gas Leak - Pictures
Got underneath the van and there are some hoses/fittings in the recessed area of the tank one of which looks damaged. Since it's spraying gas straight down it has one of those. I got a few photos but they are too large to attached here and I haven't figured out how to downsize the file
Old 08-13-2017, 07:01 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Gas Leak
Post them on photobucket or similar then link it here.
Old 08-14-2017, 02:19 PM
Re: Gas Leak
Here is a picture of where the leak appears to be coming from.
https://pix.sfly.com/7z8SAi
Old 08-23-2017, 02:25 PM
Re: Gas Leak
Took into the shop and is was a $5 plastic quick connect fitting under the tank that had been chewed on by something.
