Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 07-30-2017, 04:17 PM
Headnsouth's Avatar
Headnsouth Headnsouth is offline
DRL's never shut off
I'm hoping its just the sensor in the dash. Any ideas on where to get one?
98 Transport
03 GMC Sierra 100k
05 Infiniti G35 150K
10 Mazda 3 Hatchback 110K
16 Infiniti Q50 Red Sport 34K
Old 07-30-2017, 05:29 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: DRL's never shut off
You're sayingbthey never shut off, even when the car is off, or they never shut off when the car is on and started? If it is the latter then that is what they are supposed to do. DRL is daytime running lights and I personally think everyone should run there headlights 24/7. It makes vehicles more visible even during the day.
Old 07-30-2017, 05:53 PM
Headnsouth's Avatar
Sorry I wasn't very clear in my post.
From a cold start at night with the PB on I have no lights, which is correct. Whenever the van is started PB off I have full lighting even with the sun out.
I always thought the headlights and interior where dimmer during the day time.
03 GMC Sierra 100k
Old 07-31-2017, 08:48 PM
Tech II Tech II is offline
I must be missing something.....that light sensor, according to my diagram, only controls the DRL's, which are not the headlights, but the front parking lamps....
The headlights are not controlled by the light sensor, only the headlight switch....
Old 08-01-2017, 06:28 PM
Headnsouth's Avatar
If memory serves me correct with DRL's on this vehicle there was only marker lights running until it got dark. Now all of the lights are on.
03 GMC Sierra 100k
Old 08-02-2017, 10:47 PM
I don't think your vehicle has automatic headlights, therefore it sounds like a headlight switch problem....the DRL module has nothing to do with the headlights...
Old 08-03-2017, 04:37 PM
LMP's Avatar
LMP LMP is offline
WEll...based on my '93 with automatic headlights (and DRL) , when darkness comes, headllights go full with all other position lights and taillights. If this is the same, it looks like your light sensor does not see light anymore....however, I have never verified if parking brake will inhibit auto headlight at night....I'll have a look.....
EDIT: yes, parking brake inhibits automatic headlight ON at night.
p.s. Transport had AUtoHeadlight, but not Chevy Lumina Van
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 08-03-2017, 09:17 PM
Well, it looks like LMP is correct........I found the owner's manual online, and on page 2-59, it states:
"When the DRL are on, only your front parking and turn signal lamps are on. Your instrument panel will not be lit up.
When it's dark enough outside, the exterior lamps will come on automatically.When it's bright enough outside, the exterior lamps will go out, and the DRL will turn on.
To idle your vehicle with the DRL or exterior lamps off, set the parking brake while the ignition is OFF OR LOCK. Then start the vehicle.The DRL will stay off until you release the parking brake."
So apparently, the DRL module doubles as an auto lamp control.....
So as LMP states, the most logical problem is the light sensor.....if not that it is the DRL module....
Old 08-04-2017, 10:18 AM
LMP's Avatar
LMP LMP is offline
Just a quick check......confirm there is nothing hiding the light sensor from daylight upon the dash apron. ON my '93, it is located within the left loudspeaker opening, under the grille.
Old 08-04-2017, 01:19 PM
LMP's Avatar
LMP LMP is offline
aND here is your diagram
http://www.avigex.ca/xport/headlamps19940.pdf
Old 08-10-2017, 06:51 PM
Headnsouth's Avatar
After thinking about what I posted I didn't post the problem correctly. It's not my DRL's but my main lights both front and rear that do not shut off. Normally in the day time the DRL's will be on but not the head lights. During the day the lights are all on all the time.
I'm thinking because the car has been sitting for a while the sensor in the dash has become opaque and its not sensing the ambient light. I'll pull it and polish it. I'll let you know what happens.
03 GMC Sierra 100k
Old 08-11-2017, 03:22 PM
LMP's Avatar
LMP LMP is offline
INdeed..see what it gives...
...and if no success, then if you can pull the sensor from its place , disconnect it from the socket, and insert a wire (or, more elegant, a 1000 ohm resistor) from one pin to the other in the socket. THis will SIMULATE DAYLIGHT...AND THE headlights should extint.
Old 08-23-2017, 03:55 AM
Headnsouth's Avatar
Put a jumper in place of the sensor, no joy.
03 GMC Sierra 100k
