Old 07-24-2017, 09:47 PM
bsr2002 bsr2002 is offline
Question A/C Question, Trailblazer 4.2
I'm gonna be charging up my system this weekend and was wanting to know if I had to have the rear A/C turned on as well as the front during this procedure?
2003 Trailblazer LS 4.2L
www.facebook.com/bennyrillo
Old 07-25-2017, 11:28 AM
Schurkey Schurkey is offline
Re: A/C Question, Trailblazer 4.2
Depends on HOW you're charging the system.
Are you just blowing a pounder can of refrigerant into the system because there's a slow leak you haven't bothered to fix?
Has the system been opened to fix a leak, vacuumed, and you're adding the "sticker capacity" of refrigerant?
Are you adding refrigerant based on duct temperature readings (i.e., adding until the duct temperature stops dropping, and then 1/4 lb. additional.)
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 07-25-2017, 05:27 PM
I had the system evacuated so I could replace the compressor
Old 07-25-2017, 09:33 PM
Did you replace ALL the O-rings to prevent future leaks while the system was empty?
Did you have the system vacuumed AFTER the compressor was replaced?
Old 07-26-2017, 09:28 AM
There wasn't any leaks, the compressor went bad and I replaced it and the orifice tube. I just want to know if I need the back AC on or not while charging it.
Old 07-26-2017, 12:57 PM
Was the system vacuumed AFTER the compressor was installed?
Old 07-26-2017, 05:37 PM
Yes, can you answer my question now?
Old 07-26-2017, 10:03 PM
I can't answer your question until you answer all of mine.
Are you charging by weight, using the "sticker capacity" or are you charging based on duct temperature?
Old 07-27-2017, 01:03 AM
Simple yes or no, thanks for your help
Old 07-27-2017, 07:43 AM
Blue Bowtie's Avatar
Registered Offender
It's a valid (and important) question. If charging by refrigerant weight, you may not even need to have the vehicle running (depending upon temperatures). If charging by system performance, both halves of the system should be operating. Been there - I have two Chevy vans with dual air, and one has lost belly seals on the compressor once already.
Hopefully the proper volume of oil has already been added to the system as well as the compressor - That question has not come up yet.
