Go Back   Automotive Forums Car Chat > Chevrolet > Chevrolet Classics
Old 07-23-2017, 01:10 PM
Bradzilla9876 Bradzilla9876 is offline
Oil pressure sending unit broke off.
So I was attempting to replace the oil pressure sending unit on my 1987 r10 pickup (305) when the nipple broke off flush with the block. I have tried getting it out with an easy out but having no luck. Does anyone have any suggestions of what I can do to get it out? Should I try to use a file or drill it out? Im open to anything at this point. Thanks for any help.
Old 07-23-2017, 03:51 PM
maxwedge maxwedge is offline
A990 racer
Re: Oil pressure sending unit broke off.
Careful here, most methods will cause metal chips to fall into the hole. Is the tube cast or brass?
Old 07-23-2017, 05:41 PM
It's brass. Do you any ideas that would be safe?
Old 07-23-2017, 06:38 PM
A990 racer
Unusual for brass to seize up in the block, ,a properly sized easy out didn't work? Try getting some PB blaster down in the threads, overnight soak. Get some grease around the area to catch chips , best you can do as the brass is not magnetic.
Old 07-23-2017, 08:32 PM
I'm pretty sure it was cracked by the previous owner. It was leaking oil around it and snapped as soon as I put a wrench on it. I'm going to keep working the easy out after I soak it in blaster. I appreciate the advice and will let you know how it works out. Thanks again.
Old 11-25-2020, 09:02 AM
pitts64's Avatar
pitts64 pitts64 is offline
Be careful with those easy outs they brake too.. Then you are in trouble.
I would start with taps. Start with the smallest one that fits inside the brass and thread. Then the next size up and up until its all gone..
Or if you have another place to pick up oil pressure, just run a sheet metal screw into the brass.
I always wanted to try a counter clockwise screw into one of those deals...
My dad use to get a small chisel and work the broken piece until it screwed out. I don't have patience like that lol..
Old 01-07-2021, 09:00 AM
Ol'Jim Ol'Jim is offline
Did you have any luck removing the broken sender? If you have not already done so, an immediate oil and filter change afterward would be a really good idea.
-Jim
2015 Silverado Crew Cab 2500HD 6.6 Duramax 4x4
2002 Silverado Crewcab HD 2500 6.0 4x4 Sold 281K Great Truck
1970 Chevelle SS454 (Gave to my son 9 years ago for his 18th birthday. Yeah, I know, crazy, right? Thank goodness he doesn't drive it the way I would, -er, did...).
1971 Monte Carlo SS454 Drag Racer. The old girl finally got new paint!
1968 Camaro SS (New race car project). Caged, Tubbed, Back-Half/Ladder Bars. Rolling Chassis (For now).
The Following 2 Users Say Thank You to Ol'Jim For This Useful Post:
pitts64 (01-08-2021)
Old 01-08-2021, 06:22 AM
pitts64's Avatar
The good news is its brass which is soft and will not ruin any of the hard parts in the engine...
The Following 2 Users Say Thank You to pitts64 For This Useful Post:
Ol'Jim (01-08-2021)
Old 01-08-2021, 06:43 AM
True, fragments of brass would most likely not lock up the oil pump. Hopefully would get trapped by oil filter before they get to bearings.
Just realized original post was over 3 years old, so I imagine he got it figured out.
Hey Pitts, I like your Pontiac. Darn avatar pics are so tiny on here, looks really nice! I had a 63 Bonneville, and a 65 Catalina, both back in the mid-late 70's.
Liked the ol' 389's, those engines ran really good.
-Jim
Tags
1987 , oil , pressure , silverado , switch
