Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-22-2017, 12:35 PM
Jadkins Jadkins is offline
Electrical Issue
I have a 1997 GMC K1500 Z71. I was at McDonalds and had to pull forward to wait for my food and while i was waiting apparently the reserved sign had fallen in fro t of my truck and i didnt realize before driving forward over the sign. After this my drivers side turn signal stopped working along with the brake light. I went home and checked the wire harness but found no damage in it, not even on the trailer harness. Then next day I went to a mud event and on my way there about 2 hrs away from home the transmission went into fail safe mode and ever since then when the truck warms up it only has 2nd and third as long as I shift into second manually and it shifts hard. I have checked the fuses for the brake light and turn signal with no luck. The circuit board in the tail light was bad so I replaced it with no luck. The bulbs are good and all fuses I have checked are good. Would these issues go hand in hand or do I have two separate issues going on.
Thanks,
Jeff
