Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 07-18-2017, 10:46 AM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
You Can't Believe What's in Your Cooling System !
I recently posted a THREAD here about my Radiator - which no one has replied to......
Anyway - I bought a new radiator because my system was overheating.
It was 27 years old......
Once the old radiator was out, I BACK FLUSHED my engine with my Garden Hose and discovered a LOT of "Stuff" was in the cooling system !
Here is what came out after back flushing five times with the Heater Lever in the ON POSITION !
BACK FLUSH = Running the water backward thru the Thermostat Port WITH THE THERMOSTAT OUT !
This loose trash (some of it 1/4 inch long!) would block up the new radiator tubes withing a few minutes of starting up the engine ! It also blocks the Heater tubes and cuts down on your car's heater output....
My advice (for what it is worth) is - back flush your cooling system every couple of years to get chunks of rubber (peels off old hoses ?) OUT of there !
DoctorBill
Old 07-18-2017, 02:14 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: You Can't Believe What's in Your Cooling System !
Just so you know the coolant flows through the heater core whether the heater is on or not. The change in vent position is what decides in if you get heat or not.
Also getting garbage in the coolant system happens on every car. This is why it's recommended to flush and change the fluid on regular intervals.
