KYB Adjustables
I lowered my car 2" so I then decided to get the KYB Adjustable shocks. When I adjust the shocks, I really don't notice as much difference as I would think. In fact, it is so little I'm not even sure it is different. You know how your mind messes with you. If you expect something to change your mind will make you think it has. But anyway, is this a normal thing. Or should there be a significant difference. Could I have installed them wrong?
Also, if anyone has this set up on there Integra, what did you do with the bump stop that was under the stock dust boot in the front? |
You should cut the bump stops
I feel a difference with my KYB AGX's with them on different setting. I doubt they are installed wrong. |
WHAT DIAL ARE THEY SET ONE....CAN MAKE A DIFFERENCE...I THINK
The name's Adrian 1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills 1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills 2006 G35 Coupe 6MT - Stock 2011 CR-Z - Stock |
Cut the bumps like in half? How much should I cut. I just remember seeing that no cutting was necessary on my car, but the truth comes from experience.
1/2 should be good, leave them a little larger & if your suspension bottoms out, then trim some more. Your really shouldnt have a problem bottoming out the suspension with "normal driving" on good springs/shocks.
every article ive read on doing aftermarket shocks/springs says cut the bumpstop in half. i dont think any of them were specifically for integras, but it seems like its pretty universal.
96 Accord EX 5spd coupe - black --- AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter --- pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES |
