Go Back   Automotive Forums Car Chat > Buick > Terraza
Old 06-26-2017, 03:15 PM
Rmerrill3 Rmerrill3 is offline
07 Buick Terraza ground / starter issue
Ticking when attempted to start. Checked the battery, good. Tried to start again. Ticked once. Didnt mess with it. Months later, charged battery, same thing. Replaced starter and charged the batt again. When I turn the key get the tick, however my gages then shake until the battery is out of juice (maybe 25 seconds). Ignition switch, line fuse, ground. Where do I start? Appreciate any assistance.
Old 06-26-2017, 03:35 PM
aleekat aleekat is offline
Re: 07 Buick Terraza ground / starter issue
25 secs on the battery attempting to start? Your battery is toast. Unless you measure the voltage while trying to crank or take it to any auto parts store that will do a load test. Just getting 12v while sitting is no test.
Post back, that's what makes Forums Work.
Old 06-26-2017, 04:00 PM
After the tick I turn the key back off, then my guages shake until the battery dies. Battery is less than a year old.
Old 06-26-2017, 08:43 PM
Doesn't matter if it's 1 day old. Unless you test it properly you are just guessing.
The Following User Says Thank You to aleekat For This Useful Post:
Tech II (06-26-2017)
Old 06-27-2017, 03:13 PM
I will get it tested. If that is it I will kick myself
Old 08-12-2017, 10:09 AM
Was a bad cell in the battery. Kicking myself!!!
Old 08-12-2017, 04:42 PM
thanks for posting back. At least you didn't start throwing parts at it.
