Old 06-21-2017, 02:17 PM
kenman1717 kenman1717 is offline
Evap filter reroute 2015 2500.
2015 Silverado 2500 w/6.0l, evap filter above filler neck is plugged full of mud, because this is a bush truck. Have cleaned several times, but I know it will keep happening. I have done the reroute on the older trucks where the solenoid is behind the gas tank, run 5/8 hose to under the hood and put the filter there so it doesn't fill up so easy, that was a GM bulletin. I wanted to do that here but the solenoid is at the front of the tank and I can barely see it, let alone access it. Maybe it has something to do with the truck being a reg cab long box. Has any else tried to reroute this filter from the filler neck, up front on one of these newer 13' up body styles?
2003 Chevrolet Silverado 4.8l w/4.56 gears
2002 Chevrolet Silverado 5.3l
2001 Chevrolet Silverado 6.0l eclb
