Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-16-2017, 05:49 PM
Acampbell_2022 Acampbell_2022 is offline
2005 lincoln la blows hot air....1000 dollars to get ble nd doors fixed..help me do a quick fix
Went to an a.c. shop and they are trying to drag me.... How can I manually open the ble nd doors....it blows heat on ac
Old 06-24-2017, 09:35 AM
shorod's Avatar
shorod shorod is online now
SHO No Mo
Re: 2005 lincoln la blows hot air....1000 dollars to get ble nd doors fixed..help me do a quick fix
Are you sure the issue is a blend door versus a DCCV? Did the shop do a thorough diagnosis? Did they provide you with a detailed invoice on what they did and what they plan to repair/replace?
-Rod
Old 07-17-2020, 05:06 PM
Kmassey9806 Kmassey9806 is offline
I have a 2005 lincoln ls v8 with heated and cooled seats. My seats blow cool air... my test on ac is showing codes 1251, 1262, 1265, and 2426. (We had a computer put in from a different car 2004bc ours was causing it to miss and had it reflashed so it would work. Runs fine now) It blows heat but doesn't blow cold air. Its not heat but its not ambient air. Its a little warmer than ambient air but not as hot as the heat. Do you know what this could be? My husband said he put a gage and freon to add freon and it says full.
Old 07-18-2020, 01:47 AM
brcidd's Avatar
brcidd brcidd is offline
See if heatertreater.com can help you...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-19-2020, 10:44 AM
shorod's Avatar
SHO No Mo
Just to be clear, are you saying that one of the seats is not blowing cold air, or are you referring to dash vents? If dash vents, is the issue on both sides or just one side?
The heated and cooled seats use Peltier devices and are completely independent of the systems used to get heat and cool from the dash vents.
-Rod
