Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 06-13-2017, 12:14 AM
Khunter0226 Khunter0226 is offline
2000 Mercury Sable Cranks But Won't Start
I just replaced my starter on my 2000 mercury sable and it only cranks but it won't turn over prior to that it had been sitting for 6 months. When it went out i knew it was the starter but I had 2 cars so I didn't worry about it until now. I went And got the battery charged and it still didn't start. Do I have the starter hooked up wrong ?
Old 06-13-2017, 08:27 AM
aleekat aleekat is offline
Re: 2000 Mercury Sable Cranks But Won't Start
If you had the starter hooked up wrong you'd have some melting wires, smoke, etc. You need to determine whether it's a spark or fuel delivery issue.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Khunter0226 (06-13-2017)
Old 06-13-2017, 01:57 PM
Ok thanks I'll check that out a friend of mine said I should check my fuel filter.
Old 06-13-2017, 03:33 PM
I doubt fuel filter. 6 months sitting is not very long. Try some starting fluid, it if fires up then fuel delivery problem.
If it doesn't, suspect spark.
Old 06-13-2017, 04:17 PM
Where should I Spray the starter fluid ?
Old 06-13-2017, 09:22 PM
Air intake .
Old 06-15-2017, 01:18 AM
Air intake .
Thanks turns out I had bad battery terminals.
Old 06-15-2017, 09:10 AM
Sometimes it's the simple things...
Tags
sable , starter
