Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-12-2017, 01:42 PM
DZ989 DZ989 is offline
04 Impala brake hammering
So about a year ago I replaced the rotor and brake pads on the drivers side front end of my Impala. Ever since I can remember the brakes would slightly hammer when getting on the brakes, but I never felt like it was a huge issue. Well now looking back I realize I should've looked into it, as the brakes are now clattering when coming to a stop with the pulsating feeling the whole time. I took off the brake assembly and rotor, and noticed that my sway bar was also cracked. Is there any chance the cracked sway bar would put more pressure on the drivers side of the car? Never had an issue with the passenger side or rear. Not sure if I will have to get fresh pads and rotor to go with the sway bar. It didn't get much winter use (maybe a thousand miles on the highway) and the pads still have wear left. Maybe I'm missing something really simple here but I'm beyond frustrated with this car and all the headache that has come along with it.
Old 06-12-2017, 01:56 PM
Tech II Tech II is offline
Re: 04 Impala brake hammering
So, a year ago, you replaced the rotor and the pads on the driver's side.....what did you do to the passenger side at that time?
Old 06-12-2017, 01:59 PM
Just replaced the brake pads. The rotor was in good shape. Drivers side rotor was damaged so it was replaced.
Old 06-12-2017, 03:43 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Like pads you should change rotors in pairs. You don't want two different thickness rotors on one axle. (ie front or rear)
Also, rear pads and rotors could cause brake chattering. The sway bar is not going to cause chattering. It would only cause a thunk when it hit something, or cause the car to lean more in corners.
When it comes to maintaining cars brakes are one of the easiest things to keep track of and repair. You can't just halfass a repair and expect good results. Unfortunately repairs cost money. Doing the repairs right costs a little more initially, but will save you time, money, and headaches in the long run.
Old 06-12-2017, 06:09 PM
Ya you're right. I'm definitely not a amazing mechanic but it's cheaper when you do it yourself(properly). I'll tackle it when I get the sway bar, but ya....it costs money. I appreciate the comments. Guess we'll see how it goes.
