Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 06-07-2017, 02:58 PM
Akey77 Akey77 is offline
Negative Cable Issues or Maybe Starter Issues
I tried starting my 99 Cutlass a couple of days ago but it wouldn't turn over so I looked under the hood and saw that the negative battery cable/battery was melting inside of the connection(side post battery). The negative cable was also very hot so I checked to see if the connections were secure and they were so I tried restarting but still nothing. There was also a whining sound coming from the starter. Could it just be the starter or a wire issue OR a combination of battery, wire and starter???
Old 06-07-2017, 07:53 PM
Tech II Tech II is offline
Re: Negative Cable Issues or Maybe Starter Issues
When things melt, you have a bad connection.......bad connections create heat, and create a voltage drop, depriving voltage to the rest of the circuit...
Old 06-07-2017, 09:25 PM
aleekat aleekat is offline
And your battery may be crapping out.
Post back, that's what makes Forums Work.
Old 06-08-2017, 12:27 PM
Well I guess I'll start with the wire connection first and if that's not the problem then I'll see about the battery. Thanks Y'all
