Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-02-2017, 12:19 AM
BillyDCJ BillyDCJ is offline
07 P-71 tranny delay going into drive
after the delay it works fine when we got the car there was a pretty good size dent in the fluid pan we changed the filter and fluid and the selonoids and it still takes about 4 seconds to go into drive any help would really help .
Old 06-04-2017, 12:24 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 07 P-71 tranny delay going into drive
Does it slip during any shift (i.e. engine 'flares' during shift)? Sounds like a low pressure issue. If you changed the filter, make sure that the seal from the old one was not stuck in the valve body. Does it make any growling or whining sounds in gear?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-05-2017, 11:08 PM
Thanks for the reply but the 4 second delay is the only problem and thats for Drive it goes right in to reverse and after the delay it changes great..
