Old 05-27-2017, 07:38 AM
circuitR's Avatar
circuitR circuitR is offline
Tamiya Ferrari F40, not for the purists
Doing a collaboration with @the_kyza from Instagram. Turning one of his renders into scale realism.
So I ordered the Tamiya F40 and was at my door in just over a week.
First up was to decide on wheels. Went with Work Meister 18" as I found the bigger diameter wheels made the car too high.
Also checked the dreaded fitment, on the rear hatch. Got a bit lucky as it is not too badly twisted.
Now probably the purists are already disgusted with the render as the wing has been removed. Well, I'm going to do more than just that.
Yep, I'm replacing the small block V8 twin turbo with a quad rotor twin turbo. I will be mating the R26B engine to the Ferrari gearbox.
Modified the front brakes to get the Meisters under the guards. Had to cut down the brakes.
Thanks for looking.
Check out my
Instagram
Old 05-28-2017, 07:07 AM
circuitR's Avatar
Rear wing has been removed. Holes plugged with sheet styrene and filled with Tamiya light curing putty.
Began opening the side vents.
Also mated the R26B to the F40 gearbox. Had to move one of the engine mounts as it would foul on and exhaust port.
Definitely looks different with the wing removed.
Now to sand and fix the fitment of the hatch and do the rear suspension.
Check out my
Instagram
Old 05-28-2017, 09:10 AM
nugundam93 nugundam93 is offline
Blarg! Wort Wort Wort!
Re: Tamiya Ferrari F40, not for the purists
something definitely unexpected, but looks to be a great build!
olly olly oxen free
Old 05-28-2017, 06:32 PM
circuitR's Avatar
Thanks, yeah the great thing about this hobby is expressing your automotive art. I'm really enjoying this. Been a few late nights lately 😂
Check out my
Instagram
Old 05-29-2017, 04:02 AM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
Definitely not for purists, but let's see how the result will look like.
At least painting the rear hatch will be a lot easier now!
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 05-29-2017, 05:23 AM
circuitR's Avatar
Ha ha! There's some serious sink marks across the top of the hatch. Still filling and sanding.
Check out my
Instagram
Old 05-29-2017, 06:15 AM
GTRfan01 GTRfan01 is offline
interesting build!
looks so different without the wing......
looks like you got the twist out of the rear hatch, was it a simple task?
Old 05-30-2017, 01:21 AM
ssasho0 ssasho0 is offline
Great project, keep the updates coming please!
Old 05-30-2017, 02:18 AM
karambolis8 karambolis8 is offline
Very intresting!
Old 05-30-2017, 06:15 AM
circuitR's Avatar
Originally Posted by GTRfan01 View Post
interesting build!
Wasn't too bad. Had to remove some material where it was hitting on the intakes on the inside and removed some material around the hinges. I have just fitted magnets to secure in place
Check out my
Instagram
The Following User Says Thank You to circuitR For This Useful Post:
GTRfan01 (05-31-2017)
Old 05-30-2017, 06:16 AM
circuitR's Avatar
Thanks! Will do my best!!
Check out my
Instagram
Old 05-30-2017, 06:23 AM
circuitR's Avatar
Still sanding and filling the hatch to remove the sinks and flatten where the wing once was. Also removed the mold lines on the rest of the body.
2 x 2mm magnets were fitted to secure the hatch. This is a must for this kit.
Hatch is starting to look better, more work needs to be done to get the gaps sorted above the wheels.
I literally spent 10 mins just looking at how it is. Pretty happy so far.
Thanks for looking
Check out my
Instagram
Old 05-30-2017, 06:09 PM
Niro750 Niro750 is offline
I am disgusted!
Not really, go ahead and butcher it, the render looks awesome. Good luck with the build
Old 05-30-2017, 09:12 PM
circuitR's Avatar
Originally Posted by Niro750 View Post
I am disgusted!
Lol, that's the reaction I want! 😂😂😂😂
The butchering will continue 😆 wait till you see what I have planned in the engine bay 😉
Check out my
Instagram
Old 05-31-2017, 05:32 AM
Thanks. It's good to know, I have the same issue with mine when i dry fitted, but i havnt started the build yet.
