Old 05-25-2017, 03:59 PM
rusted and busted rusted and busted is offline
1994 Taurus airbag code 34
My 94 Taurus airbag light is flashing a code 34 Driver airbag low resistance. It only flashes about every other time I drive the car and the horn does work. Is the problem in the clock spring or could it be the airbag? Is there an easy way to stop it from flashing?
Old 05-30-2017, 08:12 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1994 Taurus airbag code 34
Since code 34 is for a low resistance, it seems unlikely that it would be due to a clockspring. Typically when clocksprings fail, they fail open, which would be a high resistance. There are not many blocks in that circuit, pretty much the air bag, the clockspring, wire, and the airbag diagnostic monitor.
If you have a safe way to deactivate the airbag, you could try disconnecting the driver airbag, then power the system back up and see if a new code appears or if you still get an active code 34. If you still get code 34, that would suggest to me that the monitor module is the problem.
-Rod
Old 05-31-2017, 05:57 PM
I removed the airbag and tried checking for codes. This time I got a code 32 (high resistance). I went to a local pull a part salvage yard and found a low mile Taurus the same year. I got both the clockspring and the module. Installed the module first and the code 32 stayed on. Then installed the clockspring and the light didn't come on but later after I was using the car I started the car and code 34 came back. I don't think it's a wiring issue and I know the car never had a problem with the bag light before....and I really don't want to try any testing on the airbag.
