Old 05-25-2017, 02:12 PM
waterkeeper03 waterkeeper03 is offline
Working it out
P0449 Condition for computer test (i read the sticky)
truck is a 2010 silverado 5.3
i would like to know the exact conditions to trigger the computer to run this test for p0449 code.
i have 2 days to replace this part and clear the code or it will interfere with the wifes vacation (and the rest of my happiness). i have the silinoid going in tonight, need to get the truck to test and clear the CEL so my emissions will pass.
i once found the exact conditions to trigger evap testing on my ford, but cannot find online for this truck.
thank you in advance!
1963.5 Galaxie 427 5spd .. 2016 Taurus Limited 3.5 .. 2011 Jetta Sportwagen TDI
Old 05-25-2017, 03:38 PM
j cAT j cAT is offline
Re: P0449 Condition for computer test (i read the sticky)
this code will throw when the engine is started . this is an electrical problem. could be the sol coil/connector is bad or other wiring / connectors.
on the evap system the other tests are done when the fuel tank is between 3/4 and 1/4..
this code will throw all the time because the electrical circuit is messed up ,because it is not seeing the correct feedback.
The Following User Says Thank You to j cAT For This Useful Post:
waterkeeper03 (05-25-2017)
Old 05-25-2017, 03:57 PM
Working it out
so assuming wires are all intact, all i have to do is replace the part and turn the key? EXCELLENT
thank you
