Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 05-24-2017, 10:05 AM
Jleggyota Jleggyota is offline
93 Toyota pick-up 22RE wont start. Help!
93 22RE. Needed a battery. Son started to install backwards. Positive cable started to smoke a little before I noticed it. It did not burn. Now the starter will not turn over, no interior accessory power (radio, turn signals, dome light, etc..) the headlights still work and the door buzzer. It will push start and run fine. Any suggestions
Old 05-24-2017, 12:28 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 93 Toyota pick-up 22RE wont start. Help!
check the main fuse in the fuse box, should be a large 60-100 amp main fuse or possible a fusible link next to battery
The Following User Says Thank You to Crvett69 For This Useful Post:
Brian R. (05-26-2017)
Old 05-25-2017, 11:43 AM
That's exactly what it was. Didn't appear blown but definitely the problem. Thanks for the help!
