Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-18-2017, 04:24 PM
Alc00b Alc00b is offline
Possible Electrical Issue?
For the past 3 weeks my car has just randomly refused to start. It's a 2010 Tahoe. I've had it towed twice with the first diagnosis of a new starter and the second that the main "bus line" was loose. It drives fine and then without warning will just not start back up. Lights and accessories all work, just no engine turn over. I have noticed that the Bluetooth stops working and randomly a power mirror won't fold in but then after restarting it's fine. Until it's not and it won't crank at all. Any ideas on what else could be the issue?
Old 05-26-2017, 10:26 AM
j cAT j cAT is offline
Re: Possible Electrical Issue?
what is a bus line ? sounds like B/S.. check for loose fuses should be set in place very very tightly.
Old 05-26-2017, 11:58 AM
aleekat aleekat is online now
Had a car once that had battery cable corrosion deep inside the cable not at the ends. Had the same symptoms for 3 yrs. Finally replaced the cables and never an issue since.
Post back, that's what makes Forums Work.
Tags
electrical , tahoe
