Old 05-12-2017, 11:48 PM
critterzdad2 critterzdad2 is offline
1991 buick park ave
I need help. Engine is cutting out going uphill. No one wants to tackle older cars here or they charge huge amounts to tinker. Is this a fuel issue? Fileter? Pump? How can I diagnose this?
Old 05-13-2017, 08:45 AM
Blue Bowtie's Avatar
Registered Offender
Re: 1991 buick park ave
The fuel pressure should be monitored while driving. Expect to measure anywhere from 37-45 PSIG depending upon load. If pressure is low there could be various reasons, including a filter, pump, regulator, or line problems. If the pressure is within the normal range the diagnosis would move to other parts of the system.
It is also worthwhile to note that the ignition system may operate normally while idling but fail under load if there are problems with spark plugs, wires, or coils.
Old 01-05-2018, 12:57 PM
dplookin dplookin is offline
My response is too late, but on older cars, it is usually a vacuum leak that causes this problem.
Old 01-05-2018, 09:01 PM
Tech II Tech II is offline
Yes, the problem should have been resolved by now....but I agree with Blue, the problem was more likely secondary ignition.....
