Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 05-11-2017, 10:31 PM
Andi38 Andi38 is offline
Faulty sensor on my rear lights...
Hi guys..
My 1998 5 series is telling me a have a rear light not working on the dashboard and yet all my lights work. I looked at manuals, Internet etc but with no avail..
Can anyone help?
Where is the sensor in the taillight assembly? If I knew that I might know where to start...
Old 05-12-2017, 05:21 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Faulty sensor on my rear lights...
You didn't happen to install LED bulbs did you?
If so then that is your problem and you likely need to install resistors.
Old 05-12-2017, 05:40 AM
No it just came on, on its own.. I haven't changed anything in my lights at all..
Old 05-12-2017, 06:37 AM
Blue Bowtie's Avatar
Registered Offender
The sensor is not in the lamp assembly. The BCM system monitors lamp current flow through shunts. If lamp current is below a threshold when lamp circuit voltage is present, the warning will appear.
As Steathee brought up, LEDs draw very little current, and changing to LEDs without adding some parasitic load to "fool" the system would generate the warning.
Old 05-12-2017, 06:43 AM
Registered Offender
The Cadillac system from 50 years ago (yes, 1967- 50 years) was far more effective. It used fiber optics to monitor actual lamp output instead of electrical load, and reported that to the driver. In another 20-30 years, perhaps the vaunted German engineering will catch up to old Detroit, err, Flint.
In the interim, check ALL the rear lamps, including the dual license lamps, side markers, etc.
Old 05-12-2017, 07:55 AM
Ok thanks for that... Looks like I'm stuck with a faulty warning light permanently then...
It's wouldn't bother me as much apart from the fact it goes "ding!" Everybody time I start the car...
