Old 05-05-2017, 06:23 PM
sanders71 sanders71 is offline
ABS and transmission problems linked?
2001 2500HD 8.1L Allison 5 speed transmission. The ABS indicator and brake light came on during a few easy stops where the abs activated even on dry pavement and slow speeds. During the same trip and just a few miles later, the transmission kicks out of gear and the indicator flashes. Putting in neutral and back into drive the truck will move but only for a few feet before it does it again. Does the same in any gear, neutral "resets" it then it kicks out again. Only code I'm getting is a p1781 which I think is a transmission code but not sure. Could these two issues be related as they both occurred at the same time? I'm kind of at a loss right now trying to diagnose. Thanks
Old 05-05-2017, 07:01 PM
Blue Bowtie's Avatar
Registered Offender
Re: ABS and transmission problems linked?
Service Bulletin
Subject:
Allison LCT1000 P1781 or P0802 Setting in the ECM
Models:
(01-05 Chevrolet Silverado) and (01-05 GMC Sierra) and ( 03-05 Chevrolet Kodiak) and (03-05 GMC Top Kick) The following diagnosis might be helpful if the vehicle exhibits the symptom described in the PI.
Condition/Concern:
Some customers may comment that the Service Engine Soon indicator lamp is illuminated. Technicians may find DTC P1781 (model years 01-02) or DTC P0802 (model years 03-05) (Transmission Control Module - Incorrect Voltage Level on MIL Request Circuit) stored in the ECM. This condition will usually occur during engine start up. This code sets when the ECM and TCM do not communicate properly on the initial "hand shake" during power up. One module may be powering down during crank due to a low voltage situation.
Recommendation/Instructions:
Note: For 2001 vehicles refer to TSB 01-06-04-020 for the latest ECM calibration. Check the vehicle for a possible weak battery or a dead battery in dual battery applications. Also check for possible poor battery cable connections, poor grounds, UBEC connections, or possibly an ignition switch dropping out during crank.
Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
The Following 2 Users Say Thank You to Blue Bowtie For This Useful Post:
sanders71 (05-05-2017)
Old 05-10-2017, 04:07 PM
All grounds cleaned and batteries checked. How do I check the ignition switch to make sure it's not dropping out?
Originally Posted by Blue Bowtie View Post
Service Bulletin
Subject:
Models:
Condition/Concern:
Old 05-10-2017, 06:09 PM
j cAT j cAT is offline
I do not do diesels but on gas engines GM trucks 1990's V8 this ignition switch did cause erratic shifting problems many had success replacing it.. they had over 200K miles on the vehicle.. so if high miles change the switch.
Old 05-11-2017, 10:37 AM
When the TSB talks about checking the ignition switch for dropping out during start up, are they suggesting the electrical switch be checked/changed or the key and tumbler cylinder along with the switch? Mine does have 256k on it.
Old 05-11-2017, 03:22 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
The ABS activating is probably a bad/dirty ABS/Wheel Sensor. I know on my old '03, my ABS/Wheel Sensor was filthy on the passenger side. I was also exhibiting the same symptoms you were having while coming to a stop. Cleaned it up and it lasted another month before it completely failed. Fairly easy piece to replace.
Not sure about the transmission though. I don't think there is any relation to your ABS issue. Could just very well be a coincidence. Or may be the ABS engaging when it shouldn't is causing the transmission to act screwy. I would try and replace the faulty ABS sensor first and see what happens. One way to determine which sensor is going back is to hit the brake at a low speed, let go of the wheel and when the ABS engages, see which way the truck turns. So if it goes to the right when the ABS engages, then you know the passenger front sensor is bad/dirty. Otherwise, you'll need a Tech2 to scan the OBDII to determine which sensor is going into fault.
Sean
Old 05-11-2017, 08:31 PM
777stickman 777stickman is offline
It's the electrical portion of the IGN SW. These have 5-6 different internal contacts, one of which powers the Tranny. As suggested, it would be a good starting point to replace it.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 05-12-2017, 07:34 AM
The ignition switch is just that an electrical switch not a lock cylinder. The ignition switch has no key hole or is @the lock cylinder. it is down low at the bottom of the steering column...
Old 05-13-2017, 12:41 PM
Ignition switch replaced....problem remains. Moving on to replacing/reprogramming tcm. Hate shotgunning parts into a vehicle
Old 05-13-2017, 02:37 PM
good you replaced the ignition switch . that does fail over 10 yrs of use or gets weak on passing electrical power not expensive as well.
so next is the tranny electrical connector as that also will create the code and the drop out of gear.
you other issue is the front hubs need sensor voltage testing. the abs sensors on the front hubs do get pushed out due to rust. you will get NO codes but the brakes will not work @less than 5MPH..
the other issue can be the hub seals are shot and the hub is rusted causing the magnetic sensor to get fouled and not produce the correct output voltage @ slow speeds.
the sensor voltage must be 350MV AC or more when you by hand spin the hub .. all it takes is one side to do it ....[again NO codes will throw ]
having multiple electrical problems is good brain exercise..........
The Following User Says Thank You to j cAT For This Useful Post:
sanders71 (06-05-2017)
Old 06-06-2017, 10:27 AM
Neutral safety switch and both connectors to it have now been replaced. Same issue remains. Truck pops out of gear in reverse and drive and gear indicator blinks. If I accelerate forward a little harder it doesn't pop out but won't shift out of first gear. Also, the speedometer is not reacting at all. Time to take it to the dealership.
Sent from my SCH-I545 using Tapatalk
