Old 05-01-2017, 09:11 AM
Tunga05 Tunga05 is offline
Exclamation 2 new can shaft sensor/ still throwing code?
I have a 1998 Chevy 5.7 vortex engine, not sure of the miles as it has been replaced before I bought the truck. Problem is I've replaced the can shaft sensor two times, distributor gear, cap and rotor, even checked the timing chain (it seems good) and my truck is still throwing a bad can shaft sensor code and she has a hiccup as we're driving along. Any suggestions?? Thank you in advance 😊😊😊
Old 05-01-2017, 04:56 PM
j cAT j cAT is offline
Re: 2 new can shaft sensor/ still throwing code?
if over 175K miles on these the distributor bearings are shot. the cam shaft sensor code ? what are all the codes , that you pulled ?? distributor cam gear replaced how did the OEM gear look ? did you use the GM gear ? how many miles on engine ?
Old 05-01-2017, 07:10 PM
Blue Bowtie's Avatar
Registered Offender
Was the distributor trigger phased properly when it was installed? The CMP signal should trigger after the CKP pulse. This can be checked with an oscilloscope or meter, or can be checked with a bi-directional scanner.
Old 05-02-2017, 07:46 PM
Schurkey Schurkey is offline
If the wire harness is defective, it might throw the same codes as a defective sensor, even if the sensor itself is OK.
As said, I'm fairly sure the distributor has to be re-synchronized using a scan tool if the distributor is removed.
For the good of the Free World, DEMAND COMPENSATION FROM CHINA for their release of the Virus Originating in the Wuhan Laboratory, released (intentionally or negligently) into the world in 2019 (VOWL-19). Ten trillion to start with, increasing as needed from there, PLUS compensation for the sickened, and "wrongful death" settlements for the families of those who didn't survive. END trade with Communist China.
Old 05-02-2017, 08:20 PM
Registered Offender
The distributor CAN be synchronized with a bi-directional scanner, but it doesn't have to be. It can be done with a meter or 'scope. Physically moving the distributor (there is a little adjustment on the V-8s) should get the rising signal events back in step.
