Go Back   Automotive Forums Car Chat > Subaru > Impreza/9-2x/Outback Sport
Old 04-28-2017, 11:10 AM
mjdemaris mjdemaris is offline
Hello, new to Subaru's, tranny issue
I bought a 1993 Impreza for a daily driver, and I've noticed that the tranny won't shift into its final gear (overdrive?) until I'm like 8 miles down the freeway.
What could cause this and how do I fix it?
Thanks.
Old 05-10-2017, 01:55 AM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Hello, new to Subaru's, tranny issue
is check engine light on? have you checked the fluid with car level and running in park. also is fluid a nice red or pink? if its brown yellow or dark it needs changing
Old 05-11-2017, 02:50 PM
the fluid looks good, and full. it smells fine. and no check engine light.
Old 05-11-2017, 03:04 PM
Crvett69's Avatar
might have to take it to a tranny rebuild shop and have them check it out. most will test drive for free. but its programmed not to shift into od and torque converter lockup till fluid reaches a certain temperature, its possible your fluid temp sensor has failed
Old 05-24-2017, 11:40 AM
Any idea where the temp sensor might be on this car?
Old 05-25-2017, 09:43 AM
somick's Avatar
somick somick is offline
I would do drain/refill for starters and see what happens.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
The Following User Says Thank You to somick For This Useful Post:
mjdemaris (05-30-2017)
