Old 04-04-2017, 01:35 PM
sisson_d sisson_d is offline
Crank Position Sensor and Ignition Control Module
I have a crank but no spark condition that looks like it will likely be the Ignition Control Module (ICM) on my '08 Pontiac Grand Prix. The ICM is not cheap and I want to rule out anything else before spending the money.
I have found that the ICM is receiving a strong 12volts and has a good ground. The diagnostic procedures require next checking the output and input for the Crank Position Sensor. But I don't have the tools necessary and, with no car, I can't get to the store.
But I do have a scan tool. And it shows the fluctuating engine RPM (about 165-200RPM) when I'm cranking the engine. I believe, from what I've read, the CPS gets it's power and sends back data through the ICM. So, if that's true, and I have RPM data on the scan tool, is it safe to assume those measurements I'm supposed to read to/from the ICM are fine?
Thanks in advance,
Doug
Old 04-04-2017, 05:08 PM
maxwedge maxwedge is offline
A990 racer
Re: Crank Position Sensor and Ignition Control Module
Looks like the cps is working​.
Old 04-04-2017, 07:45 PM
StumpedGMowner1 StumpedGMowner1 is offline
Cam shaft sensor controls spark. Crank sensor controls rpm data and fuel injection. Seen a failed or failing cam sensor not set any engine trouble codes too.
The Following User Says Thank You to StumpedGMowner1 For This Useful Post:
sisson_d (04-04-2017)
Old 04-04-2017, 08:17 PM
Good to know. Thank you. I incorrectly assumed the camshaft sensor would set a code and thought it was involved directly with the CPS for RPM and other stuff.
Now that kind of worries me. Lately, every time I can't say a part is to blame with 100% certainty, the part I buy ends up not being the bad part. I felt about 80% confident and need this daily driver working again ASAP, so I ordered the ICM earlier. I was able to get a new AC-Delco unit from rockauto (next business day shipping included) $20 cheaper than aftermarket at the local parts stores. I won't get that until Thursday most likely.
Tomorrow I'll grab a camshaft sensor locally, since it's fairly cheap, and try that out.
If I only bought 1 part, it would have ended up being the other part. Now I'll have both. And rockauto's never given me a problem with returns if it's not the ICM. I'd just have to pay the return shipping.
Thanks again for the heads up.
-Doug
Old 04-07-2017, 08:50 AM
Okay, I installed the new ICM yesterday (standing outside in the freezing mist with 102 fever) and the car started right up.
I also did the cam sensor the day before, and that did nothing. But it gave me a chance to confirm the wiring for the sensor was okay. And the part it replaced had 108k miles on it. So, for $36 I wouldn't consider it a waste of time.
Thanks to all that helped!
