Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 03-26-2017, 05:25 PM
butche18ce butche18ce is offline
Pontiac
2006 Montana sv6,have o2 pre-heater not resetting,also evap not resetting.
drove several hundred miles according to the mechanic and will not reset.
any help out there?
thanks butche18ce
Old 03-26-2017, 10:28 PM
Tech II Tech II is offline
Re: Pontiac
You have to drive the vehicle, through what is called a "drive cycle"....if you do not follow the specific steps, then the flags will not reset, because each flag will not run it's diagnostic test, if not under the proper conditions.....it's not just a matter of driving a couple hundred miles....
http://www.lyberty.com/car/drive-cycle.html
The Following User Says Thank You to Tech II For This Useful Post:
butche18ce (03-27-2017)
Old 03-27-2017, 03:52 AM
Re: Pontiac
thanks for info it's the most I've gotten even from the dmv tec
butche18ce
Tags
2006 , montana/emissions
