Operating my power window
I have my 02 Chevy Malibu passenger side front door on the bench and I want to power the window up so that I can remove the door lock. I'm in the process of replacing the original door because it was damaged.
My Question is can I use a small 12 volt battery to operate the window without the door being attached to the car. I am worried that it won't be grounded as it would be when mounted on the car? hotpipes Last edited by hotpipes; 03-22-2017 at 09:21 AM. |
Re: Operating my power window
Sure- the motor is reversible, just jump positive to one terminal of the motor and negative to the other, then reverse the polarity (swap terminal leads) to reverse motor direction if needed.
Automotive A/C Engineer with: '99 IH 4700 Toy Hauler (2) '95 GEO Prizms both maroon '99 GMC Yukon '95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller. '94 Astro- 370k miles '94 Firebird Formula- 5.7L 180k miles- gone- '92 Chevy Lumina Van 3.8L 264k '86 GMC S-15 - 2.8L 154k '87 Buick Park Ave . 187k '86 Buick Park Ave 3.8L 199k miles- gone '77 Chevy Vega- 2.5L 175k miles gone but not forgotten '68 Camaro 396 4 spd RS/SS -72k miles- |
And there is no concern that the door is not attached to the car for a good ground?
No concern with door being ground. You are attaching a ground lead when you connect the battery. Also i believe if you look close the window regulator motor is on rubber mounts the the bolts go thru. Not sure on your model but i have bench tested alot of doors without them.on the car for door lock and window motor function befor reinstalling the door.
Your "ground" is coming out of your test battery negative terminal when bench checking- forget the car battery ground- besides car ground flows reversible through motor itself when activated- having nothing to do with vehicle ground.
Thank for clearing this up for me. It's good to know that I won't damage anything.
