Old 03-21-2017, 12:21 PM
ka9mgd's Avatar
ka9mgd ka9mgd is offline
Registered User
96 park avenue shock air compressor
I need diagram for hose routing for air comressor that connects to shocks on rear for 96 park avenue.
Old 03-21-2017, 09:52 PM
Tech II Tech II is offline
Re: 96 park avenue shock air compressor
Not sure why......you can route it any way you want, just make sure they are secured and are not routed near any sharp edges, that could cause a rub through condition....
Old 03-22-2017, 06:08 AM
Blue Bowtie's Avatar
Registered Offender
I am stunned. It has nothing to do with the hose routing, but it's a little disconcerting that anyone in Connertucky would use the word "compressor" to describe air moving equipment.
As for the hoses, this should be close:
Old 03-23-2017, 03:42 PM
ka9mgd's Avatar
Registered User
The hoses fell off the pump and I needed to know how to connect to the pump,it looks like there are two connections on pump.
Old 03-24-2017, 07:27 AM
StumpedGMowner1 StumpedGMowner1 is offline
There is a rectangular plug that should have the hoses glued to it and a rectangular retainer that holds the plug in place. The retainer is number 7 in the diagram that ka9mgd posted. You may need to remove said retainer and plug then glue the lines back in place. If so make sure you get left and right correct when doing so. Cant say i have ever seen this happen but after some of the wierd shit i have seen nothing is surprising anymore.
