Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-21-2017, 11:19 AM
comet240 comet240 is offline
00 1500 wiper motor electrical issue
hi last year i had ice on winshield wipres froze i worked it and i guess burned out
i had replaced motor wasn't i and then found groun problem but it had burned that motor too when i bypasse the little black ground wire and just ran it to frame of truck worked for a bit then burned out the motor i guess
i got a replacement truck for parts it works in that truck put in ym truck no goo as i figured it was the mf switch.. nope if i put my ground wire to the motor works but i don't don't wanna burn it out...
but is here a wiring diagram or test procedure to knoe where that black wire goes too... so i can cut it off at base an run new wire to it... and is there a test to know if any of these wires melted so i can repair it.. or would it be just the ground wire shorting things.... as i don't want to short out it again like to make sure that not electrical is fused shorting etc... motors not cheap.... ohm readings or whatever procedures be great please
Old 03-22-2017, 08:47 AM
Re: 00 1500 wiper motor electrical issue
here is you tube video i took yesterday
https://youtu.be/st0vZgQYEuI
getting 12 volts on the ground don't think that's right
Old 03-22-2017, 08:21 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
https://www.dropbox.com/s/s7xwosy8ar...geRam.pdf?dl=0
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
