Old 03-17-2017, 12:35 AM
Muttttly Muttttly is offline
2002 Cavalier 2.2 Sfi Idle problems/Missfire 105000 KMS on car
Hello everybody been fighting this problem for months now,easier to explain what I haven't done ,only gets a code when idling for a while in closed loop,sometimes ,po 300 most of time it jumps differrent cylinders rough idle, excellerates​ without issues,Starts great,I have replaced and checked vaccum lines etc Ok what I haven't done.
Have not checked fuel pressure,crank,can,knock, sensor hasn't been changed,rear ,02 sensor not replaced and ecu not changed yet.Everything else done literally..thanks
Old 03-17-2017, 09:29 PM
Blue Bowtie's Avatar
Registered Offender
Re: 2002 Cavalier 2.2 Sfi Idle problems/Missfire 105000 KMS on car
You named it - Fuel pressure. Test that with KOEO and while running.
Old 03-27-2017, 09:49 PM
Internal leak of the intake manifold.
In case someone reads this.
Old 03-29-2017, 06:41 AM
Registered Offender
Internal leak? Care to elaborate? I thought the intake was still aluminum in 2002.
Old 03-29-2017, 06:02 PM
I have the 2.2 Sfi ....plastic intake manifold
Old 03-29-2017, 06:51 PM
Registered Offender
I have a '96 2.2 SFI, and it was still aluminum then. I wasn't sure when they switched.
Old 04-11-2017, 10:10 PM
You must have a two piece manifold,As for mine yes the plastic one and it's warped causing a internal leak.
