| WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
BMW M3 E30 DTM 1/12 Conversion/Scratchbuild
Hi,here are the first pics from my latest scratchbuild/conversion project.
I want to create a BMW M3 touring car.The car won lots of champions ships all over the world. Here are the first steps to make the mold of it. ![]() ![]() Lots of changes to the master. ![]() On the inside i made lots of sanding. ![]() The base plate for the body. ![]() Looks fine. ![]() The wooden frame to hold the silicon. ![]() Put together and hold with stripes in place. ![]() The master was brushed with a thin coat of silicone to prevent it from airbubbles. ![]() ![]() Outer frame sits into the place.Ready for casting. ![]() The hole for fill in. ![]() Mold is filled with 3,5kg silicone. ![]() After one night its ready for molding.The inside looks fine. ![]() The block for the inner core. ![]() ![]() Ready for casting with quick setting-resin. ![]() ![]() Casted and ready for some sanding. ![]() ![]() The frame was rebuilded for molding the silicone. ![]() Some cleaning is necessary,but the molds looks good. ![]() ![]() And here are the result. ![]() ![]() ![]() ![]() ![]() ![]() The first castings looks very good.Only some smaller bubbles at the front.But i try to prevent them with a different filling of the mold. I do my best. Next step are the wheels/rims. Thanks Christian |
Re: BMW M3 E30 DTM 1/12 Conversion/Scratchbuild
Wow, another amazing project of a great car also I love. Will follow u closely as usual Chris !
Paolo - LoveGT40 Modelworks website www.alsoldatino.com my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber FB: https://www.facebook.com/alsoldatino |
| The Following User Says Thank You to lovegt40 For This Useful Post: | ||
Capri-Schorsch (03-10-2017)
ummm, wow!
Will be watching this with wonder. |
| The Following User Says Thank You to malscar For This Useful Post: | ||
Looks awesome
| The Following User Says Thank You to E46nm52 For This Useful Post: | ||
Excellent skills...
wonderful!! I love that car
Chris, nice project!
Try to cast with pressure chamber *– it will remove air bubbles from the resin. |
Thanks for the hint with the pressure chamber.But how big should this be for my molds?I dont got enough space for building,so where i should put this chamber?
Next step are the two different mirros. ![]() ![]() ![]() Thats the late version.The rear wing was also different,but can be changed from hand i think. ![]() ![]() Now the first version. ![]() ![]() Rims with nuts and the dashboard. ![]() ![]() ![]() ![]() 4 different versions of the steering wheel.The one i choose are the one i designed from two different ones. regards Christian |
Now the printed parts arrived from shapeways.
Many thanks to Torsten who made the design for me. ![]() ![]() ![]() ![]() ![]() ![]() The rollcage fits perfect into the body.Too good. When the body and the floor is assembled its too tight.Need to cut it and glue it together.But first when the chassis is done. Created the inner structure and sanded it a bit.Now the structure is done and need to fill the holes all around for casting. The "Fina" wheels are also printed.But i miss the outer rim ring.So i made one from an old Tamiya rim and sanded it up to 2mm. Some glue on it and the rim was ready. More to come soon. regards Christian |
Final version of the rims are ready for casting.
I changed the width of the tires a bit.Now its all fine. ![]() ![]() The next step is finish the chassis master for making the mold. Thats the final part of the model making. regards Christian |
super nice. keep on
Capri-Schorsch (06-18-2017)
The chassis master is created and i just casted it into resin.
![]() ![]() ![]() ![]() That was the last mold i need.Next are the rollcage.I got a printed one here,but needs some refitting. regards Christian |
Some parts are primed to test it.
![]() ![]() The chassis with rear trunk cover is done. ![]() Some fitting test with the BBS style rims. ![]() ![]() Overall i think its ok so.Some thinning in the wheel arches can be made maybe. But the look is ok,i think. Tomorrow i will test the Fina wheels,but they should fit the same. Than i cut the roll cage to fit it into the car. Thats the last step,i hope. regards Christian |
In the meantime i found some time to create the cage.
![]() ![]() ![]() It looks fine for me.Only the "X" behind the driver seat is a bit out of shape.But dosent matters to me.It cant be seen once the body is on. Now i hope the my CAD constructor could create a new cage out of my data. regards Christian |
Today i put the M3 on the other wheels.Looks fine.
![]() ![]() Dashboard was installed and also the steering wheel.Works. ![]() The rear wing was put in place with two pins and the exhaust was created. ![]() For the exhaust i used a piece of "Ureol" and sanded it in shape. Than i took two pipes plastic and made the angle with some heat. On top i put two "Aderendhülsen" (some electrical stuff in different sizes) as the exhaust pipes. Simple sanded it with a different angle and thats it. Now i have to cast the exhaust in resin and put two "Aderendhülsen" into the kit. regards Christian |
| The Following User Says Thank You to Capri-Schorsch For This Useful Post: | ||
gbarrbr (10-17-2017)
