Go Back   Automotive Forums Car Chat > Ford > Fusion
Old 03-07-2017, 11:01 AM
butche18ce butche18ce is offline
Unhappy ford
anybody have a problem with battery going dead over nite,have a new batt
still goes dead,pulled #3 fuse, it powers the interior lights,power windows,and
batter saver relay.it started the next morning. any thoughts? it also has a gem module that runs the battery saver.
thanks for any help
butche18ce
Old 03-15-2017, 08:50 PM
TaurusKing TaurusKing is offline
Re: ford
Do a search online on how to hookup a multimeter and do a power draw check, should only be a few milliamps when car is off. Remember to tape down the alarm switch for the open hood. Takes a bit, there could be a couple of auto power drops down to the base draw. Look online, easy to do. If over recommended draw, start pulling fuses. If you already definitely know, probably a diagnosis of the circuit and part is in order.
The Following User Says Thank You to TaurusKing For This Useful Post:
butche18ce (03-16-2017)
Old 03-15-2017, 09:07 PM
aleekat aleekat is offline
Re: ford
http://www.aa1car.com/library/battery_runs_down.htm
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
Old 03-16-2017, 04:11 AM
Re: ford
thanks fr info I'll tr to figure it out
butche18ce
Tags
2007 , ford , fusion
