Old 02-18-2017, 06:09 AM
FirstGear FirstGear is offline
Smile Noise from the rear drum brakes
Hi All,
When I apply brakes from speed around 50kmph I get a noise from the rear. The noise starts like 'taka taka taka..... takkk.. takkk.. tak..'. It's exactly like putting some plastic item inside an empty plastic bottle and shaking it well and then gradually subsiding the shaking. That's the closest noise I can describe it of. But when I deep press the break or intermittently press the brake the noise does not come much. I reckon the noise is coming from the rear wheel.
Once I took to a mechanic and he replaced the break washer. But the problem still persists.
Please help me to sort this out.
I recorded the noise from my mobile: https://soundcloud.com/kadijah-foun/new-recording-3 (please volume up your device )
Car make: Perodua
Model: Viva Elite Ezi.
Thanks for your time.
Old 02-24-2017, 07:03 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Noise from the rear drum brakes
I have no idea what a "brake washer" would be. Does your car have 4 wheel disc brakes, or do you have drums in the rear? That noise sounds like a rust ridge on the inner or outer circumference of a brake rotor that is now turning in to part of the braking surface.
Take a look at your rotors inside and out to see if there is an area where the rust appears like it's starting to get polished. If so, replace the rotors or, if they still have enough thickness remaining, have them machined.
-Rod
Old 05-22-2017, 06:11 PM
Dale85 Dale85 is offline
I very much agree with Rod. It sounds like it's with the rotors. Curious to know what causes it too.
