Go Back   Automotive Forums Car Chat > Buick > Rendezvous
Old 02-17-2017, 09:10 AM
aleekat aleekat is online now
Ignition switch, starter relay or starter?
2007 . Have an intermittent starter continues to crank even though key is in run position. Figure those are the only 3 things that could affect it. Any troubleshooting or guesses. Or am I just going to have to replace parts? I have lubed the ignition switch. So it never has stuck in the "start" position.
Post back, that's what makes Forums Work.
Old 02-18-2017, 09:27 AM
Tech II Tech II is offline
Re: Ignition switch, starter relay or starter?
I would be leaning towards the relay....go to the relay center, and swap the relay with another with the same number on it, and see if that takes care of the problem....if it does replace the swapped out relay....
Old 02-18-2017, 09:58 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Sometimes it is just the starter itself with the bendix hanging up.
Old 02-19-2017, 01:15 PM
I'll start with this easy fix. Let you know.
Old 03-03-2017, 08:32 PM
Update. Been 12 days since switching the relay. So far no starter running after cranking. Thanks
Old 03-03-2017, 10:47 PM
Stealthee's Avatar
Good to hear it sounds like a simple fix.
