Old 02-13-2017, 10:51 AM
somick's Avatar
somick somick is offline
Timing belt too tight?
1999 4 cylinder Accord. 155K miles.
Whining after I did some work on the balancer shaft. Did I overtighten the belt?
I followed the FSM procedure: moved the crankshaft three teeth counterclockwise and then I PUSHED the balance shaft tensioner down with my finger. The balancer belt became tight but I thought that it was supposed to be like that.
Did I make a mistake?
Is it possible to readjust the belts without taking everything apart?
My plan is to put the crankshaft at TDC, loosen the tensioner bolt one turn, rotate the crankshaft (20-30 degrees counterclockwise) and then simply tighten the bolt back.
Will it work? Will the balancer belt tensioner spring put enough tension on the belt. The spring looks very weak.
I hope somebody will have a solution to my problem!
Regards,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 02-16-2017, 11:18 AM
somick's Avatar
Re: Timing belt too tight?
The title was supposed to read: balancer belt because it was too tight and that what was making the noise. I wanted to edit the title but it did work.
The instructions in Honda FSM are a bit vague. They do not specify how tight the belt supposed to be. In other words: tight but not that tight.
So, according to my plan, I aligned the mark on the pulley with the mark on the timing belt cover and unscrewed the tensioner bolt one turn. I thought I heard the tensioner moved. I tightened the bolt back.
No more whining! I think I hear something but most likely I am just paranoid!
The best test was this morning because my wife said: "I do not hear that sound anymore..."
