Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-02-2003, 05:29 PM
lord-ahriman lord-ahriman is offline
Unhappy My beemer is sick
I just did an inspection on my BMW, and here it is what the guy told me:
"Found right side lower control arm bushing worn, and front struts and upper strut mount are worn. Suspect cadillac converter is somewhat plugged. Vehicle does not have good acceleration. Also noticed surpentine belts are worn along with the tensioners."
Can anyone tell me if this is bad. and how much this would cost to repair.
btw. this is a 1995 BMW 3.18i
thx
Old 07-02-2003, 06:43 PM
RACER D12's Avatar
RACER D12 RACER D12 is offline
Send a message via AIM to RACER D12
Well the first line has to do with your suspension so thats some thing you would want to get fixed in the near future. Also who is this guy who looked at your car doesn't sound very professional...Suspect, somewhat, Vehicle does not have good acceleration. Its a 318 its not suspost to be fast.
Lindsey Boost Enhancer, Blitz EBC, Hot Air Intake, Koni Yellows
Old 07-05-2003, 12:59 AM
lickem66 lickem66 is offline
I just did my control arm bushes and front struts.. Try bavauto.com for bushes and struts.. about 230 USD for struts and 35 USD for bushes..
The labor was about another 200 USD at BMW indy mechanic...
Huge change in the car tho.. drives like new..
Have your mechanic check ball joints too..
Old 07-05-2003, 01:02 AM
Just re-read your post.. don't just do one side on anything that deals w/suspension..
cadillac?? do U mean catalytic? Cat's are sorta pricey.. check bavauto.com, alloembmw.com, etc.
I hope go gawd there is no cadillac in your bimmer!!!
Old 07-14-2003, 03:22 PM
gavelez gavelez is offline
Send a message via AIM to gavelez
As far as your surpentine belts and the belt tensioner, I just had mine replaced, cost me about $300 for all of it. If your tensioner is bad, you will notice a rattling sound everytime the ac compressor kicks on.
Old 07-14-2003, 04:04 PM
rdog28 rdog28 is offline
Maintenance ain't cheap
I've replaced control arm bushings ball joints. Both are fairly pricey but will greatly improve handling. Check the websites mentioned in an earlier post and see if you can order the parts and have your mechanic install to save a few bucks (although they probably won't warranty the work this way). Good luck.
