Old 02-07-2017, 04:35 PM
MarkWilliams64 MarkWilliams64 is offline
Ambient Air Temperature Sensor
2007 Grand Caravan SXT 150K
Outside Air temp began reading higher than the outside temp.
Check Engine light came on and when scanned at Autozone a code for a bad Ambient Air Temperature Sensor was identified.
Upon inspection I found the sensor broken off from the mount.
Purchase a replacement from Rock Auto.
Replaced no engine code or miss reading until today while driving to work in heavy rain. Van showed temp of 96 whIle it was 40 deg. Outside. On the way home the temp read 120 and actual outside temp was 56. Temperature reading dropped all the way to 100 by the time I got home and the check engine light came back on.
Thoughts please.
Thinking of buying a replacement connector from RA next but would like opinions.
Old 02-10-2017, 12:06 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Ambient Air Temperature Sensor
Might try hitting it with a hair dryer making sure the connector is good and dry then apply dielectric grease to keep water out.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
MarkWilliams64 (02-11-2017)
Old 02-10-2017, 02:54 PM
j cAT j cAT is offline
call up rock auto for another china part replacement.
Old 02-11-2017, 06:33 PM
I found it bare wires all fixed now.
Spliced the wires with butt joints with heat shrink tubing.
Also greased the connection as suggested.
