Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 01-30-2017, 11:53 AM
iretired95 iretired95 is offline
Polaroid PBC-56J wireless backup camera
I want to find out if I can connect the camera to the backup wiring so the camera turns on when in reverse? The receiver plugs into the 12 volt plug in the console of the car. Supposed to operate wirelessly. Does the Equinox have any constraints when hooking up additional items like wireless camera's to the backup wiring?
I tried this hookup on my 2002 Ford Windstar and it will not work. I have found out Windstar's made after 1999 has the wiring so it cannot handle additional hookups. Hoping Equinox hasn't the same constraints.
Old 02-01-2017, 04:27 PM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: Polaroid PBC-56J wireless backup camera
What year is your Equinox? When you say "backup wiring", what exactly do you mean?
AFAIK you you should be able to tap into the reverse light circuit of any Equinox. It's 12 volts and wouldn't be any different than adding trailer light wiring.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 02-01-2017, 04:43 PM
It' 2007 Equinox. So you think hooking up at the taillight reverse bulb won't cause a problem? This way the monitor will only come on when I put the car in reverse.
Couldn't do this in my 2002 Windstar as all the monitor did was flicker. Yet if I put the camera across the battery I would get a clear look from the camera.
Thanks for your help.
Bob
Old 02-01-2017, 11:40 PM
Ruley73's Avatar
Bob
You could try connecting directly to the reverse light circuit and see if it works. If it doesn't, just implement a relay for the camera's power connection. Use the reverse light circuit as your trigger signal to close the relay.
My rides:
- Steve Smith (Red)
Tags
camera , wireless
