Old 01-26-2017, 10:48 AM
somick's Avatar
somick somick is offline
Power steering pulley. Left handed nut?
I will be rebuilding my power steering pump on 4 cylinder 1999 Accord. YouTube videos show left handed nut for the previous generation (1997). Is it the same left hand nut on my 1999?
The newer pumps, according to YouTube, have a normal right hand rotation.
Regards,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 01-26-2017, 03:44 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Power steering pulley. Left handed nut?
Look at the way the pump spins when the engine is running. To loosen is generally the opposite of that.
Old 01-27-2017, 09:22 AM
somick's Avatar
Regards,
Sam
Yes, that what I thought. If look from the driver side the engine rotates counterclockwise. So to unscrew it I should go clockwise.
Thank you,
Sam
Old 01-28-2017, 11:32 AM
somick's Avatar
WRONG!
The thread is normal. To tighten turn clockwise, to remove turn counterclockwise.
Sam
Old 01-28-2017, 11:59 AM
Stealthee's Avatar
If it is a normal counterclockwise bolt then the pump spins clockwise. Otherwise you'd have the potential for the bolt to back itself out.
Old 01-28-2017, 03:56 PM
aleekat aleekat is offline
Thank you,
Sam
I'll ask the obvious. Are you facing the pulley?
Post back, that's what makes Forums Work.
Old 01-29-2017, 10:41 AM
somick's Avatar
Yes I am standing at the driver side looking at the pulley.
Instructions for the timing belt installation tell me to rotate the engine counterclockwise. So I figured out that that is the normal engine rotation. To tell the truth I do not remember how it rotates when running.
Sam
