Old 01-25-2017, 04:39 AM
rwh531 rwh531 is offline
Send a message via Yahoo to rwh531
Fuel Injector question
So my 95 jimmy has some sort of fuel issue causing it to sputter/die unless I use supreme gas plus an octane booster (issue started just in the last few weeks).
Replacing the fuel filter today but I wanted to know what the likelyhood of this being an injector or more serious problem.
Also notice that my exhaust is not running as cleanly as normal making me think Catalytic converter but I don't see how that would effect engine performance though I admit I am not very knowledgeable of the ins/outs of the vehicle as it's never given me any issues in the 5 years i've owned it thus the only thing I've done is changed out the oil and oil/air filters (not even changed the plugs (as they were new when i got it and i've only put maybe 15k miles on the rig.
Old 01-25-2017, 05:18 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Fuel Injector question
If the cat is plugged it will cause the engine to run rough due to blocking flow.
The Following User Says Thank You to Stealthee For This Useful Post:
rwh531 (01-25-2017)
Old 01-25-2017, 01:57 PM
Thank you, Turns out it was the fuel filter. Was a pain to replace, wish their was some type of extension tubing you could buy to relocate the filter to a more accessible area.
Old 01-26-2017, 06:38 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Interesting find. I'm not quite sure why increasing the octane would temporarily mask a fuel filter issue. Thank you for following up with what you found.
-Rod
Old 01-26-2017, 03:37 PM
Stealthee's Avatar
I can't see how it would have myself. Higher octane is harder to burn, so my belief is he was experiencing placebo effects. Also octane boosters barely work. When it says it raises the octane 2 points, it is raising 93 octane to 93.2 octane.
