elecronic problem from Italy
electrical problems after replacement of the engine of my typhoon in 1993: before dismounting it was all right, now the water temperature indicator rises slightly and comes light on the engine problems after a few seconds. We changed all temperature sensors, thermostat, but nothing changes. the engine ,cold or hot goes in motion, but cold if you switch it off after 1 minute, switching on again if seems flooded. tester says that water temperature is very low. we no longer know what to do
Re: elecronic problem from Italy
Either the coolant temp sensor is bad, connected improperly or the cooling system is air bound and needs to be bled.
| The Following User Says Thank You to maxwedge For This Useful Post: | ||
ctesla (05-07-2026)
thank's . we will try !!
