Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 01-11-2017, 10:30 PM
chevy06burban chevy06burban is offline
Oil pressure gauge reads too high
I have a 2006 suburban. Yesterday I started it on cold start and gauge went straight to 80 psi. The weather has been rainy and in the low 40's in the mornings. I've checked oil level and it is good. Last oil change was about 1000 miles ago. When engine has warmed up gauge still reads 80 psi. Any ideas what's going on? I'm thinking, and hoping, its just the sending unit.
1993 Chevy K1500 Silverado Z71 5.7L 4L60
1972 Chevy K5 CST Blazer 5.7L TH350
Old 01-12-2017, 01:56 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Oil pressure gauge reads too high
How many miles are on the engine?
What viscosity oil are you running?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 01-12-2017, 08:36 AM
Truck has 135,000 miles and I always use 5w-30 oil.
Old 01-12-2017, 08:42 AM
j cAT j cAT is offline
if this 80 psi suddenly occurred then its electrical problem , probably the oil sender or the dash stepper motor [gauge] what oil was used conv/synthetic ? who made the oil filter ? these use 5-30wt oil. also the use of conventional oil is not recommended in these engines. pressure gauge should be 40-60 psi with synthetic 5-30wt. hot or cold. conventional oil when cold will get is to 75PSI .. 40deg F is not really that cold ... 20 deg F and lower is cold... when zero hits all sorts of weird sh*t happens..
Old 01-12-2017, 03:51 PM
I've had my truck for almost 5 years. Always use synthetic 5w-30 oil with a Bosch filter. Never had any problems and like posted earlier it's been about 1000 miles since last oil change. Pressure gauge use to run about 40 psi. Now for 3 days gauge goes straight to 80 on cold or warm start and doesn't fluctuate. No warnings pop up either. Just baffled.
Old 01-12-2017, 05:40 PM
good info !!!!!!!!!!
wiring or oil pressure sender .. these do fail sometimes it has been reported .
possible the oil stepper motor but on a 2006 I would check out the oil pressure sensor/wiring /connector / any ground wire for it .
The Following User Says Thank You to j cAT For This Useful Post:
chevy06burban (01-12-2017)
