Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 01-05-2017, 08:28 AM
bbenavitz bbenavitz is offline
Panoz GTWC Steering Rack
Just thought I would update anyone who needs to replace their steering rack. I had seen some previous threads on this site where people chimed in about different year and part numbers for the correct steering rack which did not work when I ordered them (shafts out of the rack were too long and wrong diameter for our tie rod ends). I called Brandon at PAD and he said the correct part number was and A1 Cardone 22-207 which happens to be a part number for a 1989 Mustang. I am getting the part today and will update after I get it in.
Old 01-05-2017, 01:31 PM
Re: Panoz GTWC Steering Rack
Further update on the steering rack. My car is a 1998 GTWC, chassis #13. Brandon from PAD said the part number was an A1 Cardone part #22-207 and after buying it locally it was the correct part. It is a 1989 Mustang part number. Only modification I had to make was to shorten each shaft by 1.25" on each side so as to screw the tie rod ends far enough to match the original length. However, the main bushings on my Panoz are some sort of Delrin and I cracked them getting them off. I have a call to Brandon to see what they originally used but I am guessing it is some aftermarket part from White Side or something similar.
The Following User Says Thank You to bbenavitz For This Useful Post:
CMPanoz (01-13-2017)
Old 01-06-2017, 11:15 AM
jmarsey jmarsey is offline
Energy Suspension 4-10103-G
2006 GTS Chassis#60 TT1
Husqvarna 701sm & 901
1969 Triumph Daytona
Boss JBL
NASA NorCal Coach - 2012 TTA Champion
The Following User Says Thank You to jmarsey For This Useful Post:
