Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 12-31-2016, 01:07 PM
writemoore writemoore is offline
97 Pontiac Bonneville cluster panel issue
Hi, I just replaced the cluster panel in my 97 Bonneville. The cluster is getting power because the lights are working. The check gauges light is on. The problem I am having is now none of the instruments work at all. I used a code reader, but the check engine light isn't on so I didn't get any codes.
I am at a loss as to what to do. There isn't a security light that comes on, so I don't think that is it. Since the panel has been replaced I have been able to put it in gear. I moved the car a little in the driveway to make sure it would work.
Thanks
Tags
bonneville , check , cluster , gauges , panel
