Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 12-31-2016, 09:46 AM
Painindaas Painindaas is offline
Not heating
I have a 2001 ls with the v8 in it.When I first bought it it was overheating.Fallowed procedure to bleed system and a clear jelly pushed it's way out of the heater bleed valve.Well got it purged,but thermostat hose would not stay on when driving.Noticed that it was brittle and broken so I replaced it and the whole engine fill with a aluminum one.When installing I put in a new thermo.Purged system.It did not over heat,hose stayed on but now there is no heat coming from heater.Please help me diagnose the problem for I have two young ones that have to ride in this frig to get to appointments.Thank you
Old 12-31-2016, 09:49 AM
aleekat aleekat is offline
Re: Not heating
Whatever that clear jell was probably clogged up your heater core. Need to flush/backflush the core.
Post back, that's what makes Forums Work.
Old 12-31-2016, 09:52 AM
Re: Not heating
I have read that.But I can't find any info on which hose on fire wall is the outlet hose and which is the inlet.Could you help with that.
Old 12-31-2016, 10:21 AM
Re: Not heating
Doesn't matter. Flush both directions.
