Old 12-29-2016, 07:37 AM
edwing666's Avatar
edwing666 edwing666 is offline
Compatible tires and wheels set for Tamiya's Morris Mini Cooper 1275s
Hi dears,
I'm looking for a set of wheels and tires, wider, compatible with this Tamiya kit:
The wheels of the original model were 10 inches. I would like to build this car with wide wheels.
Also, I take the opportunity to ask if anyone knows of the existence of some detailed set for this kit (PE and resin parts).
Thanks
I wish you a happy new year
"The madness deserted of the reason creates monsters, but together they create the mother of the arts." Goya
"La locura abandonada de la razón crea monstruos, pero unida a ella es la madre de las artes." Goya
Old 12-29-2016, 04:42 PM
iceracer1's Avatar
iceracer1 iceracer1 is offline
Re: Compatible tires and wheels set for Tamiya's Morris Mini Cooper 1275s
I used a set of Aoshima KAI parts SSR mesh. I cut some tyres and glued them together to fitt on the wheels. You have to make your own set cause anything on the market is too big for the mini. There isn't a grade up set for this kit btw.
Good luck.
The Following User Says Thank You to iceracer1 For This Useful Post:
edwing666 (12-31-2016)
Old 12-31-2016, 08:05 AM
edwing666's Avatar
Good luck.
Dear friend, thank you vey much for you answer.
I wish you a happy 2017.
Old 12-31-2016, 12:39 PM
rallymaster's Avatar
I used tires from a celica GT-R and they fit well, but I had to scratch my own rims...
should see if I can find back some pics anywhere...
Phil
The Following User Says Thank You to rallymaster For This Useful Post:
edwing666 (01-02-2017)
Old 01-02-2017, 12:56 AM
edwing666's Avatar
I have found photos of a conversion made for SLOT. The modeler has done a good job, he has used the wheels of a Scalextric F1 (1/32). Interestingly, the huge wheels of a 1/32 scale F1 coincide in size with the wheels of a Tamiya's Mini Cooper in 1/24 scale. It may seem crazy, but if scratch techniques adapt the Mini Cooper wheels to the F1 wheels, it could work.
The way to make the fender flares is one of the things that has impressed me the most.
