Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-28-2016, 12:37 AM
demotim00 demotim00 is offline
Question 1998 Ram 1500 5.9L V8 heat question
The heat was not working too good when I bought my truck last Tuesday. It would barely get luke warm if that. Had the heater core flushed out today. Now I do have heat, however it takes about 20-30 minutes of driving before the heat kicks in and start to get hot. Despite the truck getting to about 180 degrees or so a lot sooner. Does this indicate that theirs a problem with the heater core, or likely the thermostat. Also I notice they sell thermostats from 160 degrees up to factory spec of 192 degrees. If i were to buy a lower temperature thermostat, would that mean the heat should kick in sooner?
Old 12-28-2016, 06:30 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 1998 Ram 1500 5.9L V8 heat question
A bad thermostat would result in the engine either overheating (if stuck closed) or not staying fully warm (stuck open)
A lower temp thermostat would mean less heat. When the thermostat opens and closes has nothing to do with heat operation.
My guess is you have a parital heater core blockage.
Old 12-29-2016, 07:02 PM
Ok thanks
Old 01-06-2017, 01:52 AM
I had the shop that flushed the heater core take another look at it. They said it was just an air pocket in the cooling system. The heat seems to work and keep you from being cold but it dont get so hot you gotta turn it down. It also blows cooler air when not moving and warmer air when moving. Is that normal for this type of truck?
Old 01-06-2017, 07:48 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
1st off #1, it's pretty cold where you're at.
Mine blows hotter air running down the road.
My heater blows warmer air on fan speeds 1, 2 & 3 but the air is cooler on step 4.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Old 01-11-2017, 01:21 AM
Seems to be the same way my heat is. Although I'm not 100% certain my heat is where it should be as even today with the temps being in the 50's. While it does blow hot, it just doesn't seem to get so hot in the truck you gotta turn the heat down and a friend of mine who's owned 2 dodge rams around the same year even said this evening that it doesn't blow any where near as hot as either of his haved or does. Just not sure what else could be causing it to not blow as hot as it should.
