Old 12-18-2016, 11:46 AM
gw84's Avatar
gw84 gw84 is offline
Send a message via MSN to gw84
'99 silverado temp gauge
When I first start the vehicle, it's obviously at the 100 mark and will gradually move up once it gets warmed up. When it reaches almost (but not on) 210, the needle stops. I've never seen it get fully to the halfway mark on the gauge, it always hangs out just to the left of it. Once it's good an warm it stays at this point and doesn't budge until I turn it off and it goes back down to 100.
Is this normal or is there something wrong? T-stat perhaps? It just seems like any other vehicle I've had, it'll fluctuate a bit more (as will oil pressure).
This ain't your grandma's car!!
Old 12-18-2016, 09:38 PM
brcidd's Avatar
brcidd brcidd is offline
Re: '99 silverado temp gauge
Sounds great to me- Don't take the readings too seriously- just note what is normal operation, so that when things go awry that you can recognize a true issue. Those dash gauges aren't calibrated and are intended for reference- absolute engine coolant temp can be and should be read with a scan tool- in other words the dash gauge may be off by 15 degrees- reading what looks to be 210 and the 195 degf thermostat be operating correctly.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 12-19-2016, 01:43 PM
j cAT j cAT is offline
these temperatures of the coolant will , should not change when @the normal temp... normal temp is 195 deg F .. this is with a scan tool .. gauge is pretty accurate on these. now if it does vary on this/your vehicle then that may mean a leak / air bubbles / head gasket / low coolant .. over the years I did have this coolant temp vary 2X.. this was a bad T stat. coolant temp would drop when at normal temp would not hold @195 F..........
Old 12-21-2016, 01:47 PM
gw84's Avatar
great, thanks guys!! I remember on the k1500 (my profile pic) the oil pressure started getting really low, it wasn't long til it bit the dust. So I'm always trying to pay attention to the gauges!
Old 12-26-2016, 06:49 PM
phipps phipps is offline
I have a 2007 Silverado and have a ScanGauge on it. My temp gauge gets to just left of the 210 mark and stays there. The ScanGauge reads about 160 when it reaches that point and I've seen the SG read up to 220 and the gauge doesn't budge.
Old 12-27-2016, 07:57 AM
the scan gauge may be reading another sensor those SG are tricky. I have one that I have programed for my toyota to read the tranny temps toyota has 2 tranny temp sensors one for torque converter other for pan . I had to call up SG to find out which one . I also programed the SG for my truck tranny temp. it works but is tricky to setup. your 2007 may have 2 coolant sensors one for dash one for engine .
Old 12-27-2016, 08:03 AM
I set up my SG to read tranny temp also. Wasn't too difficult, lot of numbers! LOL
Hadn't thought about the dash gauge possibly having a separate sensor.
