Old 12-16-2016, 07:02 AM
Zonic2001's Avatar
Zonic2001 Zonic2001 is offline
Need info on 2016 Ford GT LeMans
I will be building this 1/24 scale kit soon. Have searched pictures on-line and found many of the exterior but not many of the cockpit with interior wiring and electronic boxes details. I have a pic of the front dash but none from the rest of the cockpit. Nothing on the footsteps or either side of the driver. Therefore, I'm asking here to see if anyone can help. Thanks for reading my post!
Old 12-17-2016, 08:33 AM
Zonic2001's Avatar
Re: Need info on 2016 Ford GT LeMans
Kept looking and using different search engines and finally found what I was looking for.
Old 12-18-2016, 01:34 PM
wadny wadny is offline
Please share - I have the Profil 24 kit and could also use some references! Thanks.
Old 12-18-2016, 06:22 PM
Jayban Jayban is offline
Try here
http://www.hotrod.com/articles/exclu...acing-ford-gt/
Jeremy
The Following 3 Users Say Thank You to Jayban For This Useful Post:
vintagethunder (12-18-2016), wadny (12-19-2016), Zonic2001 (12-19-2016)
Old 12-18-2016, 08:48 PM
vintagethunder vintagethunder is offline
Quite the piece! And there is a link at the end for 177 pics!
Old 12-19-2016, 02:19 AM
Zonic2001's Avatar
Here is another link: http://www.ultimatecarpage.com/cg/62...GT-LM-GTE.html
Old 12-19-2016, 02:48 AM
Zonic2001's Avatar
Have you started the kit? This is my first resin kit and is going to need a lot of work to get it finished.
Old 12-19-2016, 02:50 AM
Zonic2001's Avatar
Originally Posted by Jayban View Post
Excellent pics specially of the cockpit. Thanks!!!!
Old 12-19-2016, 03:37 AM
Another good source here
https://www.flickr.com/photos/fordch...iracing/albums
Lots of browsing required
Jeremy
Old 12-19-2016, 04:46 AM
Zonic2001's Avatar
Jeremy
Plenty of pics!!!! Haven't seen this site before... great!!!! Man... you are good!
Old 12-19-2016, 05:39 AM
I have the Profil24 Kit as well so I had already done some research
Jeremy
Old 12-19-2016, 06:38 AM
Zonic2001's Avatar
Jeremy
Have you looked at the kit closely? I'm currently debating if I should glue the roof now before priming or after I prime and paint. If I leave it for later then, I glue the roof and I have to fill the gaps of the roof flares into the body and I think that will be tricky to do. I could mess the paint job. As well, if I glue the roof and fill the flares to the body now before priming, I think that later painting it, there will be some areas inside the air tunnel made by the roof flares and the body that I would not be able to get to it. Do you follow me? Any suggestions?
Old 12-19-2016, 07:16 AM
Take a look at Profil24 Facebook page
It shows a stage by stage way to do it
Jeremy
Old 12-19-2016, 07:35 AM
Zonic2001's Avatar
Jeremy
I went to the FB page and only saw about 4 pics of the way it was painted. Is that what you are referring to?
Old 12-19-2016, 09:40 AM
Click on the images
It shows the blue and white painted first.
Then the roof painted and added - then the next picture shows that the roof joint has been filled and blended and more red painted over the joint.
Press the arrows on the side of the images - there are a few more images
Jeremy
